Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Two-way coupling- CFD-Rocky › Reply To: Two-way coupling- CFD-Rocky
It could work, but you're then relying on the code interaction for the fluid flow field. It can work, but I'm not sure it's necessary. Have a look at the collision model in Fluent's DPM. But with non-sticky particles do you expect collision energy to be high?
