Ansys Learning Forum Forums Discuss Simulation General Mechanical Transient thermal analysis of disc brake rotor Reply To: Transient thermal analysis of disc brake rotor
erik.kostson
Hi
Can you check in the Solution (A6) and Solution Information to see if it is running:
https://www.padtinc.com/2012/07/12/solution-information-monitoring-your-solves-in-ansys-mechanical/#:~:text=When%20you%20click%20on%20the,is%20full%20of%20useful%20information.
Also as you are new, see our courses (static, transient, getting started with ansys mechanical, etc.)
/courses/index.php/structures/
All the best
Erik
