Ansys Learning Forum Forums Discuss Simulation General Mechanical Rack and pinion analysis Reply To: Rack and pinion analysis
Jaewook Lee
The gear position was adjusted and the analysis using angular acceleration was successful. However, the analysis does not proceed even if the moment condition is still given. I tried to give it as a joint-moment condition after selecting the revolving joint surface set on the pinion. The picture below shows the errors that occurred in the analysis. What did I make a mistake?
