Ansys Learning Forum Forums Discuss Simulation General Mechanical Rack and pinion analysis Reply To: Rack and pinion analysis
peteroznewman
I see a large gap between the gear teeth. That is bad. The gear teeth should be touching before the analysis begins. Create better gear teeth geometry.
