Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Hashin failure criterion › Reply To: Hashin failure criterion
Ken Ng
Hi Aurojyoti,
Thank you for the information, I tried to put the command inside the geometry but it gave me the error:
 TB,FCLI,,,1 has already been defined.  Please delete existing table to  overwrite.
Here is where the commands are inserted and both the content of two APDL are the same
FCTYP, DELE, EMAX, SMAX, TWSI, TWSR
FCTYP, ADD, HFIB
TB,FCLI,1,,16,1,,108000000,29800000,2300000,5500000,,,7800000,7800000
TB,DMGI,1,,,2,,1.6,60,0.06,0.2
These are the material properties I got:
Failure criteria:
Parallel tension = 108 MPa
Parallel compression = 29.8 MPa
Matrix tension = 2.3 MPa
Matrix compression = 5.5 MPa
Longitudinal shear = 7.8 MPa
Transverse shear  = 7.8 MPa
Fracture energy
Longitudinal tension = 1.6 N/mm
Longitudinal compression = 60 N/mm
Transverse tension = 0.06 N/mm
Transverse compression = 0.2 N/mm
I wonder what mistake I had made that cause the error?
