Ansys Learning Forum Forums Discuss Simulation General Mechanical (Rolling) Sheet thickness after rolling doesn’t match the roller’s gap Reply To: (Rolling) Sheet thickness after rolling doesn’t match the roller’s gap
sgkcompany
Hello after I change stabilization damping factor to 25 the result are getting finer. (I tried 50 but get an error)
I also adjust material to let 316 less stiffness and make 440B and D2 more stiffness.
Bouncing problem still happened (But non contact area also deform when rolls goes up)
Contact tool (very small, using lagrange, result use equally space points so only 10 result)
