Ansys Learning Forum › Forums › Discuss Simulation › 3D Design › Straight segment becomes warped while sweeping on SpaceClaim 24R1 (student) › Reply To: Straight segment becomes warped while sweeping on SpaceClaim 24R1 (student)
peteroznewman
The correct way to create the path is to draw the first straight line, change to the Tangent Arc tool to draw the bend making sure to specify a bend diameter that is at least 2x larger than the tube diameter. In this example, the bend diameter is 50 mm. The 30 degree bend angle is also specified.
Then use the Tangent Arc tool to draw the next straight segment.
Select the end point of the first line to create a plane and sketch a circle. In this example, the circle diameter is 24 mm.
