Ansys Learning Forum Forums Discuss Simulation General Mechanical Chassis Frontal Test Errors? Reply To: Chassis Frontal Test Errors?
peteroznewman
Hello Frances,
There are a few commonly used checks on the integrity of a model that are ideally done before you use the model, but more often done after you get an error trying to use the model. The check you want to do for this error is to run a Modal analysis to check that all the parts of the structure are connected together. The check reveals if they are not and then that defect in the model can be corrected.
In Workbench, drag and drop a Modal analysis on the Model cell of the Static Structural analysis. In Mechanical, you will see the Modal analysis at the bottom of the tree on the left. Drag the Simply Supported item from Frontal Test and drop it on Modal.  Under Analysis Settings for Modal, set the number of Modes to 12 and Solve.
Click on the Solution branch to see the frequencies of the modes.  If the frequency of the first 6 modes are close to zero, like 1e-5, that means you have a loose part. Create the 12 Deformation plots to animate the modes and you will see the loose part sweeping through space.
To repair that in Mechanical, you can add one or more Fixed Joints between the vertex on the loose part and the vertex it is supposed to be connected to. Alternatively, you can open the Geometry in SpaceClaim and on the Workbench tab, click the Share button and check to see that the ends of that part light up to be connected to adjacent parts.
