Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Band-to-band tunneling models Lumerical Device › Reply To: Band-to-band tunneling models Lumerical Device
April 26, 2024 at 11:42 pm
Amrita Pati
Hi Robin,
I would like to point out that the CHARGE solver solves the semiconductor Drift-Diffusion equation to calculate the relevant results. So, if you think that the physics underlying the perovskite material can be described by this model then only I will recommend using CHARGE for this simulation. Also, I don’t think we have any perovskites in the Material Database, so you will have to obtain all the paramters including the ones linked to the band-to-band tunneling model from references.
Amrita
