Ansys Learning Forum Forums Discuss Simulation General Mechanical Batch mode for 2 connected systems – how to? Reply To: Batch mode for 2 connected systems – how to?
henrique.geraissate
Hello Daniel,
Thanks for your response.
I should have said, but I am an Ansys beginner, specially using MAPDL. I have mainly used it to apply some settings withing the Mechanical interface. I didn’t know about the possibility of using a single input file with multiple solves.
So what I was actually doing now is setting up my model in Mechanical and, from there, generating the input data for the batch job submission. I have now checked the example you mentioned and could not directly get what I should do, but in the meanwhile I came across with the System Coupling system wihtin workbench, and I believe it may a be a good starting point. So far I could not even connect it properly in the Workbench (steady state thermal + static structural), but I am on the process of figuring that out.
Is this indeed a good direction? I have the impression that, with System Coupling, I will be able to connect both my thermal and structural analysis there and create a single input file. Is that correct?
Cheers,
Henrique
