Ansys Learning Forum Forums Discuss Simulation General Mechanical Analysis of steel frame with (tension only) wires? Reply To: Analysis of steel frame with (tension only) wires?
ErKo
Hi
I would suggest to model it is a cable (springs and cables have very different formulation especially for NL analysis).
Just make the cable longer so they reach the centre of the holes - then use as shown here (slide 16 below) to connect the cable ends to the edge of the hole:
/courses/wp-content/uploads/sites/2/2020/09/Connecting-Bolts-Represented-as-Beam-Elements.pdf
All the best
Erik
