Ansys Learning Forum Forums Discuss Simulation General Mechanical Analysis of steel frame with (tension only) wires? Reply To: Analysis of steel frame with (tension only) wires?
tortju
Thank you for your answer!
Using springs is a good idea. But doesn't using longitudinal springs introduce compressive stiffness (as well as tenisonal)? I doesn't seem possble (at least in "Static Structural") to assign "Tension Only" as "Spring Behavior":
