Ansys Learning Forum Forums Discuss Simulation 3D Design How to select elements to create a surface using SpaceClaim scripting? Reply To: How to select elements to create a surface using SpaceClaim scripting?
Nicole Pan Tavares
I managed to do this by giving the number of lines to be selected, and thus creating the surface only in the desired region.
selection_curves = []  # Lista para armazenar os valores de Curves[i]
for i in range(13):  # Iterando de 0 a 13
    curve = GetRootPart().DatumPlanes[0].Curves[i]
    selection_curves.append(curve)
selection = Selection.Create(selection_curves)
secondarySelection = Selection.Empty()
options = FillOptions()
result = Fill.Execute(selection, secondarySelection, options, FillMode.Layout, None)
