Ansys Learning Forum Forums Discuss Simulation Fluids Chemkin Parallel hangs on 2024R1 Reply To: Chemkin Parallel hangs on 2024R1
judy.cooper
Hi Mike:
Chemkin is a serial process unless you are doing a parametric analysis. For parametric runs, the number of parametric points that are done in parallel can be controlled thorugh the preferences:
If you set the number to 1, your parametric points will be run in serial instead of simultaneously.
Best Regards,
Judy
