Ansys Learning Forum Forums Discuss Simulation Fluids Chemkin Parallel hangs on 2024R1 Reply To: Chemkin Parallel hangs on 2024R1
jcooper
I wasn't assuming anything about distributed parallel etc ...  Only think its a good idea to eliminate complexity when running tests on parallel execution.
This type of thing is probably a bit beyond Forum support, since it is probably a systems issue.  If problems persist with simple cases, I would advise following up with your local IT.
