Ansys Learning Forum › Forums › Discuss Simulation › Fluids › mass is not balanced after convergence › Reply To: mass is not balanced after convergence
You may want to check the mesh in the doorways. It's not great as you've only got one cell on the wall thickness and it's then likely going to effect accuracy. Have a look at thin walls in Fluent.
Re the imbalance, how is your convergence, and how much of a difference are you seeing?
