Ansys Learning Forum Forums Discuss Simulation Fluids Error when trying to compile UDF Reply To: Error when trying to compile UDF
Tim LS
Hello again,
I have another question. My model has two UDSs. However, only one of them changes in value during the simulation. This occurs even when I tried to use the same source term for both UDSs. So my question is if you have any idea on what might be causing this?
Id don't know if its worth mentioning, but is is a multiphase simulation, with UDS defined in a gas phase, and the other is defined in a water phase.
