Benjamin Descorps
You should check that in the root operator is well specified in the used code generator configuration. If I refer to the CruiseControl example, the configuraiton "KCG_with_probes" is used to generate code.
In this configuraiton, it is mandatory to select the root operator of the application (in that case CruiseControl):
Hope this helps,
Benjamin Descorps
