Ansys Learning Forum Forums Discuss Simulation Fluids Chemkin Parallel hangs on 2024R1 Reply To: Chemkin Parallel hangs on 2024R1
Mike H.
Judy,
Thank you for the response. Maybe I used the wrong terminology, but I am not trying to run across different machines; I have a stand-alone machine with two processors with 10 cores each. The uncertainty analysis, I believe, does a separate solver for each case on a different core. But, I will try a simple parallel solve case (not uncertainty analysis).
For reference, in Fluent on my AMD machine, the Intel MPI is slow. I had to change it to MSMPI to get the proper speed.
Thanks!
