Ansys Learning Forum Forums Discuss Simulation Fluids Out of memory, error in “generate surface” fluent Reply To: Out of memory, error in “generate surface” fluent
CFD_Friend
Hi Bagus,
Maybe the default surface mesh size you are trying to generate is too small, which might be taking up a lot of RAM. Try changing the default values and provide a reasonable min and max size.
