Ansys Learning Forum Forums Discuss Simulation 3D Design Hiding bends and shifting values in unfolding Reply To: Hiding bends and shifting values in unfolding
subashni.satish
Hello
I see that the bend lines seem to be off in the model you have shown in the video. Do you mean you would like to hide the edge of the bend as well?
In that case, as it is a part of the geometry the edge cannot be hidden.
But if you intend to hide the bend lines, you can manage their visibility through the Layers panel. Bend lines and bend dimensions are placed on a Bends layer which is turned off by default. To change the visibility, you can turn the visibility on or off in the Layers panel.
Regarding moving the bend dimension, the dimesion can be moved in the unfolded geometry(see image 1). Once it is moved in the geometry it will reflect in the Drawing sheet as well.(image 2)
(Image 1)
(image 2)
