Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Error when trying to compile UDF › Reply To: Error when trying to compile UDF
Tim LS
The code is running now. It seems like it was a syntax error, as you suggested. Had the starting { at the same line as DEFINE_SOURCE(), instead of one line below. Thank you for your help! :)
