Ansys Learning Forum Forums Discuss Simulation General Mechanical Multistage cyclic symmetry and large deflection – temperature load Reply To: Multistage cyclic symmetry and large deflection – temperature load
fth987
It is seen that the stress values created from paths in the interstage boundary between Stage 1 and Stage 2 do not match.
The image created using the chart object shows that the curves do not have similar shapes and close peak values.
