Ansys Learning Forum Forums Discuss Simulation 3D Design SpaceClaim keeps not responding whenever I use pull function Reply To: SpaceClaim keeps not responding whenever I use pull function
Audy Maulizar
Thank you for your help. Unfortunately, my university uses older version that is 2020 R2. Though I might be able to work around it by saving the geometry file from newer version into a STEP file. I will try reducing the render to low first. I will see if it improves anything.Â
