Ansys Learning Forum Forums Discuss Simulation General Mechanical (Rolling) Sheet thickness after rolling doesn’t match the roller’s gap Reply To: (Rolling) Sheet thickness after rolling doesn’t match the roller’s gap
mjmiddle
I'm also noticing a mesh based solution. You may want to set "Element Control" to Manual on the Geometry object, and then ensure "Brick Integration Scheme" is set to full on the plate body.
