Ansys Learning Forum Forums Discuss Simulation LS Dyna SALE Sensor to Capture Element Pressure History Reply To: SALE Sensor to Capture Element Pressure History
Ian Do
Hello Peter,
To define the sensor:
- define a node ==>
- define a segment (this could be a dummy LAG segment) that this node belongs to so the code can establish a normal vector ==>
- define the offset distance along that normal => a sensor will be located at the tip of that vector
a "sensor" will be attached to a Lagrangian segment/node and moves with it.
the p inside the ALE elm which is passed by by this sensor is saved.  The
p history result may plotted from either the binary file or ASCII file output (user can choose)
*DATABASE_FSI_SENSOR
$       DT    BINARY
      0.01
$ DBFSI_ID       NID SEGMENTID    OFFSET       ND1       ND2       ND3
        11        72        37       0.5
      12        59       261       0.5
Hope this helps.
Ian Do, PhD
