Ansys Learning Forum Forums Discuss Simulation Fluids Chemkin Parallel hangs on 2024R1 Reply To: Chemkin Parallel hangs on 2024R1
jcooper
Hi Mike:
I would suggest trying a regular parallel run to rule out issues with MPI, and/or test a very simple case in parallel, such as a closed reactor.
ANSYS Forte 2024R1 uses MPI 2021 and MPI 2018, so I imagine Chemkin would be the same.  To be safe, you can try installing the MPI that comes with the 2024 release:
Best Regards
