Ansys Learning Forum Forums Discuss Simulation General Mechanical Damping in Response Spectrum Analysis Reply To: Damping in Response Spectrum Analysis
Keenan Rodewald
Thanks Avnish
The standard recommends testing the system to determine damping. My confusion is that there will be different damping values for each system mode.
Maybe a more concrete example would be helful. If there are 3 SDOF mass-spring dampers connected in series, and the leftmost is connected to ground. Say the first body has damping ratio = 10%, the second = 5% and the third 1%.
If I am trying to find the repsonse of the third body, which damping value would be used for input. Using 1% does not seem correct since this body is isolated from ground motion by 2 highly damped bodies.Â
