Ansys Learning Forum Forums Discuss Simulation General Mechanical Wafer rotation deformation Reply To: Wafer rotation deformation
dlooman
High speed rotation analysis with friction is borderline impossible for a couple reasons.  One, finite elements can't be rotated more than 2 or 3 degree per step.  Two, the element faces for contact are constantly changing so the rotation should not produce translational motion of more than 1/2 element length per step.  Even with small time steps convergence will constantly be slow making the run time almost unlimited.  Technology Showcase Example 28 in the APDL doc. is a simpler analysis than yours, yet takes 24 hours to run.  What is the object of the analysis?  What do you want to find out?
