Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Interpolation method for dpm post processing › Reply To: Interpolation method for dpm post processing
You could extract the DPM track and get the particle velocity from that. Or do you need the cell values. You need to be a little more careful defining what you want, DPM Velocity (per track), DPM Velocity (per cell) or fluid velocity per cell.
You may find some of the definitions here helpful  https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v241/en/flu_ug/flu_ug_fvdefs.html  Also, post processing for DPM is covered in the User's Guide.
