Ansys Learning Forum Forums Discuss Simulation Fluids Fluent, Intel 12th Series CPUs & Turbo Boost Reply To: Fluent, Intel 12th Series CPUs & Turbo Boost
V.P
Intel Alder Lake processors, especially the HX variants designed for high-performance laptops, are subjected to thermal and power constraints to maintain stability and prevent overheating. Even though the Max Turbo Boost Frequency is advertised at 5 GHz, the processor may dynamically adjust its frequency based on factors like temperature and power consumption to stay within safe operating limits.
You could try:
  • Experimenting with different core configurations to find the optimal balance between computational speed and core utilization.
  • Monitoring CPU temperature and power consumption during the simulation to ensure they are within safe limits.
You can learn more about CPU parallelization and performance here:  42.9. Checking and Improving Parallel Performance (ansys.com)
