Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Sweep Num Divs Grayed out for ‘Manual Thin’ when multiple bodies are present › Reply To: Sweep Num Divs Grayed out for ‘Manual Thin’ when multiple bodies are present
Ankush Choudhary
If you are using 2022R2, then it will not allow you to change the number of divisions for the multibody parts. However, if you have version 2023R1 or 2023R2, you can change the number of divisions for the multibody parts by activating the beta options.
