Ansys Learning Forum Forums Discuss Simulation Photonics Regarding box of monitors and far field simulations Reply To: Regarding box of monitors and far field simulations
Amrita Pati
Hi Prabha,
You are welcome! Would you be able to share a screenshot of the error? If you edit the Analysis Group, then click check the code at the two places (Setup-->Script) and (Analysis-->script), you will see an option called "Run Analysis". After finishing the simulation, if you click on that it will give you output messages as well as error messages.
I would be interested to look at the screenshots of the error messages. Thank you!
Amrita
