Ansys Learning Forum Forums Discuss Simulation Photonics Regarding box of monitors and far field simulations Reply To: Regarding box of monitors and far field simulations
pnair
Hello Amrita,
Thank you for the reply and a detailed explanation of farfield analysis group and the corrected script.
I run the simulation with the script suggested here. But, It is generating an error:
Target wavelength = 1.54e-06
Wavelength used = 1.54e-06
Angular distribution i=1, 1.54um
Projecting in x-y plane
Projecting in y-z plane
Projecting in x-z plane
Error: Result XY_halfspace: variable not found.
And, I am not able to visualize the farfied data in the xy_half space and its showing"failed to calculate results"
Please find the attached script that you have suggested here and I have used the same script for the simulations:
# Far field from closed box
# This script calculates scattering cross-section and far field projection in half space
# Note: The far field projection calculation assumes that all of the monitors
# are in a single homogeneous material (i.e. there is no substrate)
# If a substrate is present, results from this object will be invalid.
# If multiple frequency points are collected, the projection can be slow!! One could reduce the halfspace resolution for faster analysis.
# For more information, see http://docs.lumerical.com/en/layout_analysis_projections_from_monitor.html
# symm x,y,z: symmetry boundary conditions
# 0 for no symmetry, 1 for symmetric, -1 for antisymmetric
# Autodetection is managed by examining fields at the symmetry boundary
# For more information, see http://docs.lumerical.com/en/index.html?ref_sim_obj_symmetric_anti-symmetric.html
# do halfspace: Calculate the far field in the full half space for all frequencies. This takes longer than the 1D radar line cross sections. 1 for yes, 0 for no
# do polar plot: Calculate the far field scattering angular distribution for a specified target wavelength. 1 for yes, 0 for no
# target wavelength: Desired wavelength for polar plot. The closest wavelength recorded by the monitors will be found and used for the plot.
# halfspace res: Define the resolution of the half space projection. This will significantly affect the time to run the analysis.
# polar plot res: Define the resolution of the polat plots.
# Output properties
# XY, YZ, XZ: E, |E|^2, |H|^2 far field profile of scattered field in plane, as a function of frequency
# XY_halfspace: E, |E|^2, |H|^2 in full upper/lower half space,, as a function of frequency. Similar to standard projection from a single monitor
# Tags: far field projection closed box
# Copyright 2015 Lumerical Solutions Inc
# automatically unfold field data if symmetry BC is applied
if (havedata("x1", "f")) {
symm_x = 0;
} else {
xtemp = getdata("y2", "x");
ztemp = getdata("y2", "z");
Eztemp = pinch(getdata("y2", "Ez"));
Ez2mid = sum(Eztemp(round(length(xtemp)/2), 1:length(ztemp))^2);
if (Ez2mid != 0) {
symm_x = 1;
} else {
symm_x = -1;
if (havedata("y1", "f")) {
symm_y = 0;
} else {
ytemp = getdata("x2", "y");
ztemp = getdata("x2", "z");
Eztemp = pinch(getdata("x2", "Ez"));
Ez2mid = sum(Eztemp(round(length(ytemp)/2), 1:length(ztemp))^2);
if (Ez2mid != 0) {
symm_y = 1;
} else {
symm_y = -1;
if(include_sub){
if (havedata("z1", "f")) {
symm_z = 0;
} else {
Eytemp = pinch(getdata("y2", "Ey"));
Ey2mid = sum(Eytemp(1:length(xtemp), round(length(ztemp)/2))^2);
if (Ey2mid != 0) {
symm_z = 1;
} else {
symm_z = -1;
f = getdata("x2","f"); # get freqency data
if (havedata("index","index_x")) { # get refractive index. Required to calcualte H2 from E2
n_index = getdata("index","index_x");
} else {
n_index = getdata("index","index_z");
# define the angular resolution
phi = linspace(0,360,%polar plot res%); # user-modifiable in the Variables tab
npts = length(phi);
# define the field data matrices for angular distribution
E_xy = matrix(npts, 3, length(f)); # 3 for x, y, z component
E_yz = matrix(npts, 3, length(f)); # 3 for x, y, z component
E_xz = matrix(npts, 3, length(f)); # 3 for x, y, z component
E2_xy = matrix(npts,length(f));
E2_yz = matrix(npts,length(f));
E2_xz = matrix(npts,length(f));
H2_xy = matrix(npts,length(f));
H2_yz = matrix(npts,length(f));
H2_xz = matrix(npts,length(f));
# Identify the closest wavelength to target:
target_wavelength = %target wavelength%;
i_target = find(f,c/target_wavelength);
?"Target wavelength = " + num2str(target_wavelength);
?"Wavelength used = " + num2str(c/f(i_target));
if (havedata("z2","Ex")) { # have z data, 3D simulation
# Angular distribution calculation for a 3D simulation begins
for (i = 1:length(f)){ # loop for all frequencies
# print the frequency point number running in the loop
?"Angular distribution i="+num2str(i)+", "+num2str(c/f(i)*1e6)+"um";
n = n_index(i); # select the frequency point for the index
######## x-y plane (phi=0 corresponds to the direction (1,0,0))
?" Projecting in x-y plane";
x = cos(phi*pi/180); y = sin(phi*pi/180); z = 0;
# Calculate far field by summing contribution from each monitor
temp = farfieldexact("x2",x,y,z,i) + farfieldexact("y2",x,y,z,i) + farfieldexact("z2",x,y,z,i);
if(havedata("x1")){
temp = temp - farfieldexact("x1",x,y,z,i);
}else{
temp2 = farfieldexact("x2",-x,y,z,i);
s = symm_x*[1,-1,-1];
temp2(1:npts,1) = s(1)*temp2(1:npts,1);
temp2(1:npts,2) = s(2)*temp2(1:npts,2);
temp2(1:npts,3) = s(3)*temp2(1:npts,3);
temp = temp - temp2;
if(havedata("y1")){
temp = temp - farfieldexact("y1",x,y,z,i);
}else{
temp2 = farfieldexact("y2",x,-y,z,i);
s = symm_y*[-1,1,-1];
if(include_sub){
if(havedata("z1")){
temp = temp - farfieldexact("z1",x,y,z,i);
}else{
temp2 = farfieldexact("z2",x,y,-z,i);
s = symm_z*[-1,-1,1];
E_xy (1:length(phi), 1:3, i) = temp;
E2_xy (1:length(phi), i) = sum(abs(temp)^2,2); # E2 = |Ex|^2 + |Ey|^2 + |Ez|^2
H2_xy (1:length(phi), i) = E2_xy (1:length(phi), i) * n^2 * eps0/mu0; # for a plane wave, E^2 and H^2 only differ by a factor of n^2*eps0/mu0
######## y-z plane (phi=0 corresponds to the direction (0,1,0))
?" Projecting in y-z plane";
x = 0; y = cos(phi*pi/180); z = sin(phi*pi/180);
if(havedata("x1")){
}else{
if(havedata("y1")){
}else{
if(include_sub){
if(havedata("z1")){
}else{
E_yz (1:length(phi), 1:3, i) = temp;
E2_yz (1:length(phi), i) = sum(abs(temp)^2,2); # E2 = |Ex|^2 + |Ey|^2 + |Ez|^2
H2_yz (1:length(phi), i) = E2_yz (1:length(phi), i) * n^2 * eps0/mu0; # for a plane wave, E^2 and H^2 only differ by a factor of n^2*eps0/mu0
######### x-z plane (phi=0 corresponds to the direction (1,0,0))
?" Projecting in x-z plane";
x = cos(phi*pi/180); y = 0; z = sin(phi*pi/180);
if(havedata("x1")){
}else{
if(havedata("y1")){
}else{
if(include_sub){
if(havedata("z1")){
}else{
E_xz (1:length(phi), 1:3, i) = temp;
E2_xz (1:length(phi), i) = sum(abs(temp)^2,2); # E2 = |Ex|^2 + |Ey|^2 + |Ez|^2
H2_xz (1:length(phi), i) = E2_xz (1:length(phi), i) * n^2 * eps0/mu0; # for a plane wave, E^2 and H^2 only differ by a factor of n^2*eps0/mu0
} # end of the angular distribution for loop
if (%do polar plot%) { # polar plot for target wavelength
polar(phi*pi/180, E2_xy(1:length(phi), i_target), E2_yz(1:length(phi), i_target), E2_xz(1:length(phi), i_target),
"angle (degrees)", "|E|^2", "|E|^2 vs angle @ "+num2str(c/f(i_target)*1e6)+"um");
legend("xy plane","yz plane","xz plane");
} # end of if polar plot
# create datasets for XY, YZ, XZ for angular distribution
XY = matrixdataset("XY");
XY.addparameter("phi",phi*pi/180.); #phi angle in radians
XY.addparameter("lambda",c/f,"f",f);
XY.addattribute("E",pinch(E_xy,2,1),pinch(E_xy,2,2),pinch(E_xy,2,3)); # Ex, Ey, Ez
XY.addattribute("E2",E2_xy);
XY.addattribute("H2",H2_xy);
YZ = matrixdataset("YZ");
YZ.addparameter("phi",phi*pi/180.); #phi angle in radians
YZ.addparameter("lambda",c/f,"f",f);
YZ.addattribute("E",pinch(E_yz,2,1),pinch(E_yz,2,2),pinch(E_yz,2,3)); # Ex, Ey, Ez
YZ.addattribute("E2",E2_yz);
YZ.addattribute("H2",H2_yz);
XZ = matrixdataset("XZ");
XZ.addparameter("phi",phi*pi/180.); #phi angle in radians
XZ.addparameter("lambda",c/f,"f",f);
XZ.addattribute("E",pinch(E_xz,2,1),pinch(E_xz,2,2),pinch(E_xz,2,3)); # Ex, Ey, Ez
XZ.addattribute("E2",E2_xz);
XZ.addattribute("H2",H2_xz);
# end of the angular distribution for a 3D simulation
# Halfspace calculation for a 3D simulation begins
# calculate the far field in XY upper/lower half space
if (%do halfspace%) {
res = %halfspace res%; # projection resolution, user-modifiable in the Variables tab
u1 = linspace(-1,1,res);
u2 = u1;
X = meshgridx(u1,u2); # These three lines define the orientation of the hemisphere (ie. XY based halfspace)
Y = meshgridy(u1,u2);
Z = sqrt(1-X^2-Y^2);
filter = abs(imag(Z))<=0; # filter out any values outside of hemisphere
filter2=matrix(res,res,length(f)); # same as filter, just for all frequencies
filter3=matrix(res,res,3,length(f)); # same as filter2, just for all frequencies, Ex, Ey, Ez
for (j=1:length(f)){ # just for filter2 and fitler3 for all frequencies
filter2(1:res,1:res,j)=filter;
filter3(1:res,1:res,1,j)=filter; filter3(1:res,1:res,2,j)=filter; filter3(1:res,1:res,3,j)=filter;
x = reshape(X,[res^2,1]); # reshape coordinate matrix into a vector. This is the required form for farfieldexact.
y = reshape(Y,[res^2,1]);
z = reshape(Z,[res^2,1]);
x = [x,x]; # Concatenate a 2nd copy of the vector, for the lower half space
y = [y,y];
z = [z,-z];
npts = length(z); # size of position vector
# define halfspace dataset
E_XY_halfspace = matrix (2*res^2,3,length(f));
E2_XY_halfspace = matrix (2*res^2,length(f));
H2_XY_halfspace = matrix (2*res^2,length(f));
for (i = 1 : length(f)) { # loop for all frequency points
?"Projecting in XY upper half space, i=" + num2str(i)+", "+num2str(c/f(i)*1e6)+"um";
if(havedata("x1")){
}else{
if(havedata("y1")){
}else{
if(include_sub){
if(havedata("z1")){
}else{
E_XY_halfspace (1:2*res^2,1:3,i) = temp;
E2_XY_halfspace (1:2*res^2,i)= sum(abs(temp)^2,2); # E2 = |Ex|^2 + |Ey|^2 + |Ez|^2
} # end of halfspace for loop
E_XY_upper_halfspace = E_XY_halfspace(1:res^2,1:3,1:length(f)); # separate the upper/lower data
E_XY_lower_halfspace = E_XY_halfspace((res^2+1):(2*res^2),1:3,1:length(f));
E_XY_upper_halfspace = reshape(E_XY_upper_halfspace,[res,res,3,length(f)]); # reshape the data back into a 2D matrix
E_XY_lower_halfspace = reshape(E_XY_lower_halfspace,[res,res,3,length(f)]);
E_XY_upper_halfspace = E_XY_upper_halfspace*filter3; # set all values outside of hemisphere (ie. the corners of the matrices) to zero
E_XY_lower_halfspace = E_XY_lower_halfspace*filter3;
E2_XY_upper_halfspace = E2_XY_halfspace(1:res^2,1:length(f)); # separate the upper/lower data
E2_XY_lower_halfspace = E2_XY_halfspace((res^2+1):(2*res^2),1:length(f));
E2_XY_upper_halfspace = reshape(E2_XY_upper_halfspace,[res,res,length(f)]); # reshape the data back into a 2D matrix
E2_XY_lower_halfspace = reshape(E2_XY_lower_halfspace,[res,res,length(f)]);
E2_XY_upper_halfspace = E2_XY_upper_halfspace*filter2; # set all values outside of hemisphere (ie. the corners of the matrices) to zero
E2_XY_lower_halfspace = E2_XY_lower_halfspace*filter2;
# create halfspace dataset
XY_halfspace = matrixdataset("XY_halfspace");
XY_halfspace.addparameter("ux",u1);
XY_halfspace.addparameter("uy",u2);
XY_halfspace.addparameter("lambda",c/f,"f",f);
XY_halfspace.addattribute("E_upper",pinch(E_XY_upper_halfspace,3,1),pinch(E_XY_upper_halfspace,3,2),pinch(E_XY_upper_halfspace,3,3));
XY_halfspace.addattribute("E_lower",pinch(E_XY_lower_halfspace,3,1),pinch(E_XY_lower_halfspace,3,2),pinch(E_XY_lower_halfspace,3,3));
XY_halfspace.addattribute("E2_upper",E2_XY_upper_halfspace);
XY_halfspace.addattribute("E2_lower",E2_XY_lower_halfspace);
XY_halfspace.addattribute("H2_upper",E2_XY_upper_halfspace * n^2*eps0/mu0);
XY_halfspace.addattribute("H2_lower",E2_XY_lower_halfspace * n^2*eps0/mu0);
# end of the halfspace calculation for a 3D simulation
# end of 3D
} else {
# Angular distribution for a 2D simulation, only for the XY plane
for (i = 1 : length(f)) { # for all frequency points
# x-y plane (phi=0 corresponds to the direction (0,1,0))
?" Projecting in x-y plane. 2D simulation.";
x = -sin(phi*pi/180);
z = 0;
temp = farfieldexact("x2",x,y,i) + farfieldexact("y2",x,y,i);
if(havedata("x1")){
temp = temp - farfieldexact("x1",x,y,i);
}else{
temp2 = farfieldexact("x2",-x,y,i);
temp2(1:length(phi),1) = s(1)*temp2(1:length(phi),1);
temp2(1:length(phi),2) = s(2)*temp2(1:length(phi),2);
temp2(1:length(phi),3) = s(3)*temp2(1:length(phi),3);
if(havedata("y1")){
temp = temp - farfieldexact("y1",x,y,i);
}else{
temp2 = farfieldexact("y2",x,-y,i);
} # end of for loop 2D
polar(phi*pi/180, E2_xy(1:length(phi), i_target), "angle (degrees)", "|E|^2", "|E|^2 vs angle @ "+num2str(c/f(i_target)*1e6)+"um");
legend("xy plane");
# create dataset for XY
} # end of angular distribution for 2D simulation
