Ansys Learning Forum Forums Discuss Simulation Fluids Unable to Sample Trajectories Reply To: Unable to Sample Trajectories
OK, that's a good start. If you open the .out file in a text editor what do you see? I'm not sure what the planes do if you also select a boundary, so if the file is empty, deselect the plane and try again.Â
