Ansys Learning Forum Forums Discuss Simulation General Mechanical Help needed for steady state thermal analysis of rectangular fins and validation Reply To: Help needed for steady state thermal analysis of rectangular fins and validation
Ashish Khemka
Hi Tirth,
I think the forumula used by you is for a long fin and the forumula for a fin of finite length with heat convection is different. Can you please check the same? Also, if you can share the correlation from text book and simulation for using the formula then it might be helpful to comment.
Ashish Khemka
