Ansys Learning Forum Forums Discuss Simulation General Mechanical Modal Results not Responding to Changing Pre-Stress Reply To: Modal Results not Responding to Changing Pre-Stress
Michael Fusaro
Thanks for your reply Peter.
An additional question I have is, what might cause my 3-sigma equivalent stress from a random vibration to be much lower than the equivalent stress from the static structural pre-stress analysis?
For example, I have a part at the end of my beam that exhibits high stresses under static structural loading (~300 MPa)
When performing random vibration with the above pre-stressed static structural, the 3-sigma equivalent stress only reaches about ~40 MPa.
I understand Random Vibration is a statistical result, but I cannot understand why the stress would be significantly lower than the static case. I just want to make sure I am interpreting these results correctly.
Thanks in advance,
MichaelÂ
