Ansys Learning Forum Forums Discuss Simulation Fluids Enthalpie in transient thermal Reply To: Enthalpie in transient thermal
Chandra Sekaran
To input enthalpy material property in an APDL script, you can use the 'MPDATA' command. This command allows you to define material properties that are associated with a temperature table, which must be defined first using the 'MPTEMP' command. Here's an example script that demonstrates how to input enthalpy:
! Define temperature points
MPTEMP,1,0,100,200,300,400,500
! Define enthalpy values at the specified temperatures
MPDATA,ENTH,1,,900,1800,2700,3600,4500
In this example, 'MPTEMP' defines the temperature points, and 'MPDATA' assigns the enthalpy values at those temperatures for material reference number 1. The 'ENTH' label is used to specify that the data being defined is enthalpy. The values after 'ENTH' represent the enthalpy at each temperature point, in units of J/m^3 as suggested for a transient thermal analysis.
Remember to replace the enthalpy values with those appropriate for your specific material and analysis.
