Ansys Learning Forum Forums Discuss Simulation General Mechanical The ETABLE command has requested item = SMISC, comp=1 of element 1··· Reply To: The ETABLE command has requested item = SMISC, comp=1 of element 1···
Chandra Sekaran
For beams and springs you should use ETABLE items to get the forces. Also make sure that output controls writes everything to the results file. You can use below commands to ensure that.
The second warning may be OK. Since you have a mix of element types, it is possible smisc,1 is only applicable for some element types. So the warning simply says that not all elements in your model have SMISC,1 item.
outre,erase
outres,all,all
