Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › Ansys Ncode › Reply To: Ansys Ncode
April 22, 2024 at 2:10 pm
danielshaw
You do not need the time column in the time series file and it may be simpler to use two single column file rather than 1 2-column file. If you are using Ansys nCode DesignLife via the Mechanical embedded Add-On, the time series multipliers can be stored in an ASCII file. If you are using Ansys nCode DesignLife via the HBK interface, you need to use the nCode ASCII Translate utilty to convert the ASCII file into a DesignLife format (e.g., a .s3t file).
