Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Fluent TUI, display mesh options › Reply To: Fluent TUI, display mesh options
April 22, 2024 at 10:20 am
Can you set up the images via the GUI prior to running? Also remember that if you can set up the mesh object that it'll retain the settings it's much better than the "old" way where we needed to specify surfaces/edges and which ones every time. The images can then be saved via TUI commands in Execute Commands.Â
However, if you've no GUI on the cluster how are you creating images? Fluent displays the image to then save it, it's not a virtual image.Â
