Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Force convergence problem › Reply To: Force convergence problem
April 21, 2024 at 3:14 pm
peteroznewman
Hi Adeleine,
Check the coefficient of thermal expansion for all materials and make sure you use the correct units for temperature when you are entering a CTE value.
Check that all the materials and bodies are assigned the same reference/Environment temperature.
Try running the Static Structural model with a Thermal Condition and assign a 1 degree temperature increase to all bodies. For example, if the reference temperature is 20 C, assign a Temperature of 21 C to all bodies and see if you get a reasonable thermal expansion and reasonable stress values.
Peter
