Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Is node order in the stiffness matrix different from the node order in solution? › Reply To: Is node order in the stiffness matrix different from the node order in solution?
April 21, 2024 at 12:22 pm
dhjang4522
Hi mike
Do you mean that the node numbers seen in Workbench (Node ID) differ from those in the exported stiffness matrix?Â
