Ansys Learning Forum Forums Discuss Simulation LS Dyna Unable to run command line : elgenerate solid voxel Reply To: Unable to run command line : elgenerate solid voxel
Reno Genest
Hello Veronique,
It is good that you found a workaround. It is also weird that you have to do the first one manually. Which version of LS-PrePost are you using? Have you tried with the latest LSPP? You can download it here:
https://ftp.lstc.com/anonymous/outgoing/lsprepost/4.11/
Also, if you can send here on the forum the complete sequence of commands you are executing, maybe we can help troubleshoot.
Reno.
