Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › Help Needed: Invalid Initial Pressure Error with Two-Phase EOS in ANSYS Autodyn › Reply To: Help Needed: Invalid Initial Pressure Error with Two-Phase EOS in ANSYS Autodyn
April 19, 2024 at 7:28 pm
Chris Quan
I tested it in the commericail version of ANSYS 2024R1 Autodyn. I couldn't reproduce the error as you observed. See attached picture below.
The same material can be filled into either Lagrange or Euler grid without showing any problems.
Are you able to get the latest release of ANSYS 2024R1 and try it again?
