Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › Unable to run command line : elgenerate solid voxel › Reply To: Unable to run command line : elgenerate solid voxel
April 19, 2024 at 7:00 pm
veronique.bouvette.1
Thank you for your response! It is, in fact, the line from the recording file. After numerous attempts, I randomly found out that it works fine if I first complete one voxelization manually. Considering I have a bunch of voxelizations to do, I do the first one manually and then I proceed with .cfile for the remaining ones. My process is not completely automatic as I intended it to be, but it is the only way working for me.
