Ansys Learning Forum Forums Discuss Simulation General Mechanical Ansys motion local coordinate orientation reset in post-processing Reply To: Ansys motion local coordinate orientation reset in post-processing
Ankush Choudhary
You can create a new coordinate system, and you can change the desired orientation of this coordinate system by changing the values of the direction vectors in the orientation tab. This new coordinate system can then be used to measure the relative displacement.
For further information, please check out the Motion Document, Section 3.3.2. Coordinate System Properties.
