Ansys Learning Forum Forums Discuss Simulation General Mechanical direct solver in-core vs. out-of-core mode and RAM usage Reply To: direct solver in-core vs. out-of-core mode and RAM usage
Fabian Potschul
Thank you for your reply. I will look it up.
When the solver switches from in-core to out-of-core mode would there be a note about it in the solution output file (?), because in this case ther is no such note. That is why I am confused about the solver not having enough memory to proceed using the out-of-core mode. Additionally there should be enough free disk storage in my working directory for the direct solver to continue solving, even when using the out-of-core mode but I will definitley check that. Thank you and have a nice weekend!
