Ansys Learning Forum › Forums › Discuss Simulation › Electronics › Reluctance Force Calculation in an Electro-Permanent Magnetic Clamp › Reply To: Reluctance Force Calculation in an Electro-Permanent Magnetic Clamp
HDLI
Hello junaed.buet,
      It makes sense when the result is small because it is total force when you assign parameter force on both workpiece and EPMC body.
      You should calculate force on only workpiece, not both parts (total force should be zero).
HDLI
