Jason Bonacum
Hi Lito,
Thank you for the reply!
I'm having several issues in regard to your reply:
(1) I cannot run the Ansys License Manager because I do not have the license file locally. At least, I think that is the problem. I cannot find the license.lic file in the "license_files" folder.
(2) The lmstat command does not work on my lmutil application. It says that "License server machine is down or not responding.", but the server responds to the test in the FlexNet Publisher. I'm not sure what the problem is.
(3) I have tried the Licenses configuration utility instead of the Ansys licensing client settings, but that does not work either.
(4) The Launcher license configuration indicates "Server unreachable or license could not be found"
In general, I noticed that some of the folders and files are in different places than the instructions in the links you provided, even though I used the defaults during installation. I will try to re-install Lumerical again using the Ansys instructions (https://optics.ansys.com/hc/en-us/articles/360024508974-Windows-installation-guide). Do you have any other suggestions? Thank you!
